FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Sounds a little low. I would expect around 145. However, it could be your gauge Try another gauge if you can borrow one. If the engine has not been run recently, run it for a little while before checking compression.
I have twin 85's and if any of my cylinders(6) were 12# different I'd start looking for a reason.
You pull all the plugs when doing the test?
Let it spin up at least 5-6 times or more?
Like Frank suggested get a different gauge.
The comp with a good gauge is closer to 145-155
You can do a compression test without grounding the packs if you jump it at the solenoid.
When I did the test, I pulled all the plugs first...one thing I did not do was warm the engine up a bit first. It runs great, but just did a random test . Might have to try another gauge. Thanks again guys.
No the test can be done on a hot or cold engine.
It can run good with different comp#s.
Some later model Forces actually were designed to have different comp on the top and bottom cyl. compared to the center holes.
After the test with a different gauge. Do a de-carb with Mercury's Powertune or BRP's Engine Cleaner.
I didn't mean to warm-up the engine. If it had been sitting a good long while I meant you should run it for about 15 minutes to get some fresh oil into the cylinders and aid the seal.
