arnettjs
Thread starter- Joined
- Sep 15, 2008
- 39
All,
Brand new to boat ownership and to this forum. I just bought a 1992 18' Cajun with a 1992 Johnson V4 115 VRO outboard. Everything ran great during the test drive and two subsequent outings. However, yesterday on the lake the outboard began shutting off at/near WOT. This happened multiple times in a row until I finally slow-speeded it back to the launch ramp. The VRO tank is just over half full, new gas in built-in tank. No audible alarms are going off. Runs great at idle and slow speeds.
Being brand new to boating, I have 'dinged up' the prop pretty good. Its slightly bent on one fin and chewed up on the other two. Its a 13.25 x 17 aluminum, probably stock.
After researching many of the threads here (by the way, fantastic wealth of information!), I have learned that there appears to be an RPM limiter on most outboards (tach doesn't work but it did seem to be revving higher than normal when it cut out). Could the damage to the prop be causing the outboard to rev too much, thus the limiter killing the outboard? After it dies, it will immediately restart and run fine until I try to get up to full speed.
Other items that may be of help, the water pump pee stream is steady. Outboard starts without issue, either cold or warm. Fuel in tank is new. No visible signs of leakage at/around the outboard.
Before investing the $$ into trial-and-error (and subsequent furious wife), I'd love to narrow this down a bit. Any help will be greatly appreciated!
Sincerely,
Jeff
Sincerely,
Jeff
