What type of oil do I use for this its a v4.
Also where do I put the oil and what not? do i mix it in with the gasoline and if so how much oil do I put in? my boat has a 18gallon gas tank.
also how do I loosen up the steering? the steering wheel will turn but it takes some force... will WD-40 do the trick or do I need some other type of lube to put on the motor steering arm itself?
thanks
thanks
