Re: 1992 Johnson 150 Stalling
I'd do the easy stuff first like checking the ignition switch and powerpack. You can check the ignition switch by disconnecting the black and yellow wire from the power pack. If it doesn't die, it's the ign. switch. If the powerpack is getting hot and breaking down, you can run the engine on the muffs and warm the powerpack up with a hair drier and see if it fails.I'm bettin' on the powerpack.<br /><br />g'luck & c/6<br /><br />Hooty
