1992 johnson 225 cooling hose routing
boydog40
I found the main hose to the pee tube laying loose and I cant find where it goes, I had the power head removed to replace the steering arm back in may, today is the first day I cranked it, it is then that I noticed no water from pee tube, as well as no water inside the engine compartment, im guessing mechanic didn't connect it back to the water pump tube but not sure as I cannot find a water hose route diagram
anyone have this diagram they can send me?
thanks
boobie
Re: 1992 johnson 225 cooling hose routing
The only place I know of is in a factory service manual. Or else take it back to the guy that did the repair.
sphelps
Cool A Briggaha ! :cool:
But can you cut the lawn with it ? :D
