chead98
Thread starter- Joined
- Sep 11, 2009
- 82
Hi guys. I purchased a used 60hp Johnson 1992 (60TLEN) and everything seems to work fine except on cold starts it's takes a long time to get going. This is what I do. Put it in the water, pump the bulb till it gets hard, flip the choke and turn the key. It takes a long time to catch. It seems that the choke doesn't really do anything. It does eventually catch but I'm fearing I will wear out my starter.
I confirmed the choke is working but I didn't check to look at the butterflies internally in the carb. The fuel filter is getting gas in to it as I pump the bulb.
Once it's warmed up and running it starts very easily. But as soon as it gets cold, it takes constant turning over with the key to get it started again.
What could it be? Choke not working properly internally. What's the best way to troubleshoot this. I hope I'm not missing anything.
Thanks everyone in advance. Chris from Pickering ON
