Re: 1992 Johnson Evinrude 120 hp
The "EN" in the model number denotes that the engine is indeed a 1992 model.Unless my sources are incorrect,the L78YC sparkplug is not the correct plug for the engine.I listed the other two plugs in an above post that correspond to the 92' 120 horse motor.The YC plug is a protruding nose plug and will fire at a different combustion chamber location than the QL77JC4 or the QL16V surface gap.Install the right plugs and test run engine.If they foul out,then look elsewhere for your problem.
