1992 liberator 201...fuse box location
johnny_gogo
1992 liberator 201...can someone please tell me where the fuse box is located, i tried to start the boat with a fully charged battery, when i put her away last year (winterized) she ran...now i get nothing at the ignition, maybe a fuse popped...idk...but the outdrive goes up and down at the button on the shifter lever...weird man!
fuses are under the helm or you have dash mounted circuit breakers.
most likely you have bad connections
Lou C
look for oxidation on the fuse for the ignition circuit. happened to my 88 H-200 a few years back...tilt n trim worked but no gauges or engine cranking
