1992 Mariner 90ELPTO trim/tilt - single ram - how to change hydraulic fluid?
Bannister 6905
I suspect my 1992 Mariner 90ELPTO has the incorrect trim/tilt fluid in the system. I want to drain and refill it, but am unsure how to do that with this single-ram unit.
Aside from tilting the motor full up, supporting it with the tilt lock and then removing the drain plug, are there additional steps needed to remove the fluid that remains in the cylinder?
Any good information will be appreciated.
Thanks.
Bannister
