1992 Merc 175 Trim/Tilt Sytem
sam am I
I have it out, it's on the bench, it works/ed still............now what?
Before I out it back for 20 more yrs, what should I check....brushes at the very least? Seals? What breaks on these things that I can check before I put it back on?
gm280
Re: 1992 Merc 175 Trim/Tilt Sytem
Before I out it back for 20 more yrs, what should I check....brushes at the very least? Seals? What breaks on these things that I can check before I put it back on?[/QUOT
I'm assuming you are talking about the actual pump motor. First question is, why did you take it out? If there was no reason for the removal other then you want to check it out, then the usual replaceable items seems correct. Check the usual hydraulic seals and "O" rings and motor bushings or brushes. Other then that, unless there was an obvious problem, clean it up, repaint if you like and reinstall with fresh clean oil.
wired247
I think Sam just likes to tinker with things . Who am I to throw stones.
sam am I
No waaaaaaaaaaaaay, I'm much too busy at -5 degrees to just take things apart....geeeesh!!
I opened it up, I took a photo........on my other post that is. It's broke?
******let it be broke, let it be broke, oh plzzzzzz let it be broke**********
