griffin800
Thread starter- Joined
- Apr 3, 2012
- 12
Re: 1992 Merc 3.0L high oil consumption, need advice
well... I have bad news...
The engine has blown a hole in it... in the rear by Cylinder 4, right under the manifold.
It's quite large... golf ball sized...
I assume it was a thrown rod?
To be honest... I had half a mind to not post about it on here because... I don't want two things...
1. to assign blame on anyone for telling me to run it, because that's not how i feel at all... or...
2. to have anyone else scold ME for running it, even though i knew it had issues
"It is... what it is..." or so they say
As the story goes... I took it out in the evening to nights ago... oil level was fine before going out... warmed it up and trolled across the no wake zone bay... got into the main lake... oil pressure was fine... idling fine... no smoke.. no rattling or knocking... no high water temps...
...got it on a plane before 4000 rpm... backed off to 3100 on the tach... and while cruising along... heard a loud "pop"... not so much an explosion sound or a boom, but a pop and then the boat slowed down immediately...
i think it may have been still running on 3 cylinders for a moment, but i'm not 100% sure... I turned the key off as quickly as i could but if it was still spinning with loose parts inside i think it may have caused other damage...
...somehow, the starter housing was blown off the engine, and into the bilge....
I didn't realize this at first... but after I got emergency towed back to the marina... I was marvelling at all the oil that the engine had leaked into the bilge and checking to make sure i wasn't taking on water, and going to be pumping the oil into the lake... and i noticed the starter just sitting there... no wires attached to it... just sitting there...
so in a nutshell...
catastrophic engine failure.
My guess is that running low on oil that one time smoked some bearings? weakened things up?
For it to be so sudden and violent seems odd to me... but...
in any case...
i'm not sure if i'll be fixing it this year or putting it away for a while.
anyone have an engine for sale ?
i was thinking long block reman for $1700 and swap what's left of mine over to it...
i'll take pictures of the carnage and put them on flickr.... it'll be... educational...
-Gavin
so in a nutshell...
in any case...
-Gavin
