I'm having 2 problems with my motor:
1) I can crank the motor when I first put it in the water and it will run as far as I want to go without the warning horn sounding. However, after I shut the motor down, and then turn the key back on, the warning horn will sound (even after it has been off for several hours) and it will not quit buzzing even before I have cranked the motor. When I crank the motor the warning horn continues to sound even though plenty of water is coming out the telltale. After the boat sits for 24 hours or longer I can crank it with no warning horn sounding until I run it and then start to crank it again.
2) I was running my boat at the lake last night about 3000 rpm and the motor started to bog down (it had been running fine all day). When I pulled back to neutral it cut off. After this I could crank the motor and it would run in neutral if I would give it gas and keep it above 1000 rpm. In neutral I can rev the motor and it revs up and runs as long as I keep it above 1000 rpm, but when I put it into gear it will bog out. I finally manged to get it running in gear and it would only reach 1750 at WOT. I'm going to hook an auxillary tank and see if maybe it's just water in my gas (I hope it's something that simple). If it's not bad gas then I was wondering what else I should check and I wondered if this problem could be related to the warning horn sounding??
