1992 Mercruiser 4.3 Alpha One Gen II has water in oil after rebuild.
nola mike
To pressure test a block cooling system:
1) Remove hoses to manifolds and plug them.
And hoses to elbows?
2) Remove the 'IN' water hose, that comes from the transom, at the thermostat.
3) Either plug the open thermostat port or use it to make up a connection to a schrader valve.
4) Apply max 15 pounds pressure to cooling system. Should hold air indefinitely. You can use a mechanics stethoscope to listen for the leaking air as well.
15 will work but I would suggest 30 psi, my motor reaches almost that
Faztbullet
The intakes like to freeze and crack under the carb..... leaks water into lifter valley..
Lou C
nic420
Thank you for all your replies. I contacted the machine shop that rebuilt the heads for me and they were able to get me a replacement.
