1992 Mercruiser 4.3 w/ balance shaft and 1 piece rear main seal swap to newer year Vortec.
nic420
I am converting to Vortec and currently have a 2bbl MerCarb. Is it better to switch to a 4 bbl for more horsepower or can the same be achieve w/ my current 2 bbl? Thanks.
Scott06
Youwill need to buy a new intake manifold for the vortec heads so id upgrade to edlebrock 1409
nic420
Just in case I have to get a complete turnkey motor, does any one know if this motor will bolt in w/ my current 4.3 or does the engine mount needs to be modified? Thank you for all the advice given.
Mercury Mercruiser Marine - PLUS Series 350 MAG MPI Alpha Bobtail Marine Engine (#863611R11)​
Your motor mounts move forward about 4" you need to move the boat mounts
nic420
If converting to Vortec, do I need to change my current crank to a Vortec crank?
nic420
Rick are there any other mods to be done if you are putting Vortec heads on a non balance shaft block (but with roller cam)? Pushrods rocker arms etc? Though of doing this when I did my top end overhaul but thought there was more to it so I just replaced the old heads with reman pre Vortec heads and reused the original intake...
My current 4.3 has roller cam and non balance shaft block, will this affect the conversion to Vortec? I have already purchased the Edlebrock 1409 4 bbl Performer carb and the EDL-2519 Performer intake from Summit Racing as Scott suggested.
nic420
Without even running the numbers I can see that you are already killing that engine. Revs should be 4400-4800, so you are throwing horsepower away by being overpropped (as well as damaging it!). And if you're looking for speed, a 4 blade prop is another way to chop 3 or 4 knots off the top. 4 blade props are great for a lot of things, but top speed is not one of them.
So, let's start with those figures. From those I have calculated that you have a 1.84:1 drive. (for those who use 'slip' as a performance guide, it's at 18.5%. Ok for a boat that size, and an engine so overpropped.)
My first recommendation would be to go to a 15" 3 blade prop, but since the current engine is cracked and you are looking at replacing, I would definitely go to the 5.7.
Using Merc's prop calculator, it suggests that with the current V6, you could get your top speed up to about 35 with a change to a 15" 3 blade prop. But when I put the numbers in for a 5.7 engine, a 21" prop should put you up in the 42mph area.
So that pretty much clears up the question of whether you're current drive will work. :) (yes it will)
As for fuel consumption. Up to the point you reach 30mph, both engines will use pretty much the same amount of fuel. Once you start pushing into the 30s, obviously you're going to use more, but at the same time, you'll be putting more distance behind you. My best estimate would be that you'll use around 2 to 2.5 litres/nautical mile up to about 35mph with the V8. Any faster than 35 and I think you'll be looking at around 2.8 to 3 L/Nm.
Chris......
Will I still be able to use my current 14 1/2 x 15 SS 4 blades prop once the motor is converted to Vortec?
your crank and pistons are the same, you dont need to change them. you are only changing the heads and intake
your cam and block is fine
you may need to go up in prop pitch, however wait until you get the boat back on the water.
nola mike
You'll need a new bracket for the shift cable for the 4bbl, and I remember there being an issue here with an nla timing cover (?) for the non balance/vortec combo? Or maybe it was the non balance/non vortec? @Rick Stephens ?
Rick Stephens
That is exactly what my motor is. Just changing heads and intake. I do not remember what the push rod length was.
nic420
Can I use the Automotive vortec heads or do they have to be Marine? What's the difference?
Lou C
When I did my top end overhaul I used reman pre-vortec heads, I'm pretty sure they were just automotive heads, no different, about $550 for the pair.
nic420
Would it be okay to use a vortec block and switch over the cam and the crank from the non vortec?
Why
Crank is almost identical except provision for crank sensor on vortec
You cant just swap cranks without going thru validating journals ans bearing bores
Vortec block doesnt have a location for fuel pump so you have to run an electric pump
The gain is from the heads (combustion chambers) not the block or pistons
