maddog2
Thread starter- Joined
- Apr 24, 2009
- 94
I have a 1992 Mercruiser 4.3L engine that wasn't winterized. I have learned a valuable lesson here. Both exhaust manifolds were busted, a freeze plug under the motor mounts on each side was out. I ordered new exhaust manifolds, new freeze plugs, new spark plugs, wires, and replaced the sensor in the distributor and put it all back together....only to find that when I put her in the lake...water and oil began pumping out of the PCV hoses into the intake of the carb...OUCH !! I assume that I have a busted engine block. I did have water come out of the the two center spark plugs holes before it was put back together.
I have decided to order a remanufactured long block engine.
The engine is in a 1992 Celebrity190 bowrider. 18'-7" long.
I have a friend with an engine stand, chain hoist, cherry picker, ect.. to remove the engine..so, heres my question.. what do I need to do to remove this engine? I plan to remove the bell housing bolts from the back of the block and remove the two motormounts.
Of course, I will have to disconnect any hoses, power, fuel lines ect...
Does the engine have to be shifted forward from the bell housing to disinguage the motor from thetransom? Are there any bolts from inside the bell housing that need to be removed in order to remove this engine?
I am mechanically inclined and I have the tools, but I have never removed a boat engine before.
Please , somebody help me out here.
James in Salisbury,NC
