1992 Nissan 90, No reverse or neutral
MickeyW
Was out fishing this morning, and went to use reverse to stop, and lo and behold, No Reverse, No Neutral. it was working fine five minutes prior. In the neutral position the boat coninues to idle forward, and accelerates forward when throttle is applied in the reverse position. The helm is a Morse shifter. Even when I pull the shift lever out sideways to the throttle only position, the boat stays in gear. Runs fine in the forward position. We were about 10 miles from the boat ramp and it ran like a charm to get us back. Just had to be careful approachng the dock and loading, and thankfully no incident. Any ideas?? Do you guys think the problem is at the helm, cable, or in the lower unit???
Mickey W
1976 Aquasport Open Fisherman
1992 Nissan 90 HP Tilt/Trim
pvanv
Re: 1992 Nissan 90, No reverse or neutral
Likely shift cable problem.
