1992 Outboard 40hp C40ELRQ / timing question TDC / ATDC / BTDC setting
acadian2022
Good day all. I have a1992 Outboard 40hp 2 stroke
C40ELRQ and found repair manual however the manual refer to engine as 40 V and wanted to make sure specifications I'm looking up is correct. all the parts look the same in the manual thank you all.
99yam40
you might want to clarify what you question is about.
My C40TLRX specs are 7 ATDC and 25 BTDC so I would think yours would be also
Timing normally does not go out of adjustment.---What is the motor doing / not doing?
acadian2022
Hi thank you for your reply. in searching for a manual for my outboard the only one I was able to find in the manual it refer the outboard as V40 however all the parts look identical as mine in that manual.
acadian2022
the person I purchase the outboard from mention they payed with the timing at the moment only issue I have after changing lots of parts is on full throttle after a few minute its as if one cylinder cuts out. I ensured that all linkage are correct carbs synchronized with linkages carb opened all the way etc. I ordered a new coil since I wanted all the basic parts to be new, new CDI, fuel filter, fuel pump, gas tank and hose, starter, thermostat, spark plugs, new shifter and cables etc. I wanted to verify that the timing setting are A ok to rule any future problem. again a big thank you all for sharing your knowledge. ( compression in both cylinders are 124-125
99yam40
if you are trying to verify timing, just use a timing light to see where it is sparking at.
if not correct then chase how to adjust
acadian2022
if not correct then chase how to ad dont have
Good day, thank you for the suggestion, I don't have a timing light however a friend does and will have him come over asap.
