1992 Stratos 2250 here we go again
zool
Looks good minch!...if you have an extra piece of tube, you could make a bow thruster! ;)
kcassells
Bah Humbug says I! Just pissed I ran out of ching ching and you are kickin a doublescribble. Looks Great Minch! keep ergoing!:joyous:
ahmincha
I totally understand kfc that was my hold up to last month.
ahmincha
Ok so I am starting to cover the tops of my stringers with 8.6 oz. is there a trick I am using epoxy
kcassells
You could of gone with csm. With the 8.6 oz just exaggerate the width a little and you'll simply come back with either the razor trim method {just prior to full cure} or the ole grinder method. Either way still wet out the top of the stringer, place glass then wet that out. Probably use a roller for the 8.6 oz. Well it's 2:30 here my time so I'll bet it's already done! :)
sphelps
yep get someone else ta do it while you tend to the beer cooler ! :D
I thought you did not use csm with epoxy ...
kcassells
Nah... you can use csm. You may be right Sam. Just checked with USC they recommend poly or poly ester for resin of choice. In this case 8.6 oz is probably the better
choice. Just checking on who's awake here today. Certainly not me! :)
zool
Just pre-wet the stringer, cut your stringer caps from the8.6oz cloth, lay the piece over the top, wet out the top 1st, then each side from the top down, use alligator clamps to hold it in place if needed.
ahmincha
Well ground off yesterdays caps lots of air bubbles. havving same problem today. Would 6 oz be easier?
zool
thinner is always easier, if your deck sits on top of the stringers, then you don't need anything....
I should note, I don't use a roller, just a chip brush, and work the air down the stringer side...in fact, I havnt used a roller for any of my glassing, just resin and brush ;)....but that's why it takes so long hehe
kcassells
Like the Zool said. Epoxy pb is all you need to cap the stringers to the deck. {hehe I still add chopped fibers"**
ahmincha
Thanks for the speedy replies. Yesterday I did the chip brush method but obviously I didn't do it correctly. I would do the top first then work done the sides. But it would keep moving the cloth and cause air bubbles.
So I used the 6oz same brush method and seems like it working out.
Yes my deck will sit atop of stringers but I am determined to get this right plus I figure it cant hurt to have it on there.
Happy fathers day to all the fathers out there!!!
Second Chance 248
Looking good over there!
When I glassed in my strakes with mat tape, I cut the bristles down to around 2" then stipple the air out, you can actually hear the air popping out.
ahmincha
pbed the fuel tank ply in
k
ahmincha
Ok so originally this was wasted space
j
But I am thinking I could keep my batteries inb here and probably other junk also.
This is how it looks now
j
j
I am thinking I could run pvc thru both bulk heads so I can run the rubber hose for draining the deck storage and run a pvc to drain any water I get in fuel tank area to bilge.
Then I would tab in a flat floor foam under the floor and have storage area
The access would be from above thru a access door I install in the removable floor panel
k
PB160001_zps8937826b.jpgP6210002_zpsz2rgnikc.jpgP6210001_zpsei3jyrvx.jpgP6210003_zps2d5mohw2.jpgP6210004_zpshqmi8qmc.jpg
Does this make sense
