zool
- Joined
- Aug 19, 2012
- 3,433
I'm confused... why would you epoxy the transom and let it dry before it goes in the boat? Or am I not following correctly?
One reason is you want to soak the wood in the resin, to add longevity, you also want cured resin on the wood, so it doesn't wick up and dry out the lams when you glue and tab it in...some pre glass it, then install..
You can just put raw wood in, and wet it then, but any voids between the outer skin, and the wood, can get compromised when drilling out holes for accessories, or other transom items..if its pre-coated, any water that does find its way between the skin and core, wont start soaking the transom right away.
