1992 v4 90 hp starting issues
romontano
Hello this motor is new to me and runs well after starting but whenever I start it I need to engage the fast idle lever and choke it regardless of whether its been running or cold. Its not a very smooth idler but to my knowledge none of these engines are. At higher throttle settings she runs smooth, but if I shut her down and restart I have to use choke and high idle settings. Has anyone else had similar issues? Thanks. RomanM.
jjacobs007
Re: 1992 v4 90 hp starting issues
sounds like the linkage is out of wack.check all the linkages for engagement timing.
romontano
Thanks. I'm assuming you mean the throttle linkage?? Or is there a more relevant linkage around the carb which you might be talking about? R.
