1992 V4 90HP - which Oil injection tank kit do I need ??
MuskyHunterDave
Hello. . . . I am looking to hook up the now disconnected VRO oil injection system on my 90, but am curious if they "OMC" tamks are all the same, or should I be looking for one type in particular.
I looked on ebay, and found two:
1. http://cgi.ebay.com/ebaymotors/ws/e...m=320037008735&ih=011&sspagename=STRK:MEWA:IT
OR
2. http://cgi.ebay.com/ebaymotors/ws/e...m=200037397525&ih=010&sspagename=STRK:MEWA:IT
Is there a pump in the tank, or does the VRO pump do the job at the motor?
Thansk in advance for the Advice, you guys are real life savers for use semi laymen :)
Dave
MuskyHunterDave
Re: 1992 V4 90HP - which Oil injection tank kit do I need ??
I guess those links did not work, so the tank item #'s on ebay are:
1. 200037397525
3. 320037008735
The one closes in 3 hours, so some quick advise would surely be appreciated :)
THANKS AGAIN
funpilot
I can only relate to what I have on my boat.
200037397525 looks like the one I have on my 1990 90hp. The hold down clips are missing, but you could rig some kind of strap.
320037008735 has some kind of return hose fitting that I'm not familiar with.
Hope this helps
fp
funpilot
BTW, the VRO combined with the fuel pump system does the pumping. The squeeze bulb is only used to prime the pump. I don't think I've ever had to squeeze the VRO bulb once in service.
fp
