run on water whole day about 4200 rpm good as soon i pass 4200 rpm it will start bogdown,after take home run idle ,it backfire(poping),every 10-15 second,what i need to check,already check spark all good(with spark tester),compression all good,
thanks for the tips,also like to ask u one more question,i pump all the gas out fron tha gas tank because have trash in it,fill up with new gas,and i prime the bulb,it not pumping after 20-30 try,finaly suck the gas ,is that mean i have air leak before the prime bulb or after the prime bulb?thanks
