1993 140 looper GEARS
reelbrothers
Have above Twins on 23 Formula, Wanted to see if anyone thought going to V6 gears is feasible, would love to get 30 cruise at lower than 5000 RPM , I know, I can go propeller route, but 17 pitch gives good bite and should keep load lower on shaft? Anyway, this is my sunday night ponderence.
Thanks
V 6 lower units will fit on the V 4 loopers.----I believe the commercial models used the V 6 lowers.-------See a dealer to discuss performance.
jimmbo
In 85 and 86 the first couple of years of the V4 loopers were introduced they had the V6 gearcase with 28:13 gear ratios. Around 87 or 88 they switched to the smaller V4 gearcase. They were having a lot of hesitation problems with the 2 liter loopers and along with changes to carb calibrations and timings, the smaller V4 case was substituted. Smaller prop, lower load on the engine. A lot of V6 cases have a 26:14 ratio
Faztbullet
The V6 is a 1:85 ratio and the V4s with the large case used different ratio of 2:1.You would benefit using the larger case with 2:1 ratio as you could swing a larger diameter prop.
