rothfm
Ensign
Thread starter- Joined
- Sep 26, 2006
- 918
I know, another 140 idle/rough running!...I searched alot of posts but still looking for a bit of advice.
Got this motor awhile back from an older guy for 250 bucks, after the usual checks (124psi-all), I did the usual Carb rebuilds, water pump, plugs/wires, filter, Stats etc....
Barrel testing proved it ran decent, so I mounted it on the boat for additional testing.
1) Rough low RPM IDLE TO 2800RPM.
Ive gone over the OEM manual checking Link/Sync items..I dont want to overly mess with this until I get some further advice. Idle, up to about 2800 is rough. Immediately after that it smooths out and runs beautifully. Cyl drop test yeilds all are firing. Squeezing bulb yields same, its not flat. WOT is almost 6k on my tack. . Previously went thru the carbs with wire strands, Berrymans, gummout...and I cleaned the throttle plates.....However did not take out the flat plugs.
I'M HESITANT TO START TURING THE IDLE ADJUSTMENTS JUST YET.
2) TEMPS ARE WAY LOW:
Whether in the barrel or in the water, Seems the water is flowing all the time, not regulated by the Stats at all. The motor never gets warm. Close testing in-water today saw idle temps of 80-95......and after a long run only in the 70's. I actually disable Fast-Start so I could control the warm-up via the remote lever.
I did the stats exactly the way the housings were originally. However in the OEM book (Pic attached), they say to unscrew 2 haves of a cap on thermostat, and show a pic of a pointed "cap" with a spring in it. I'm pretty sure I dont have this. See square #5.
3) Voltage:
at idle is 13.2...With only a few RPM's jumps up to 14.7-14.8. Seems high to me--but had to ask.
Thanks in advance for any input.
3) Voltage:
