runninfarmer
- Joined
- Jun 28, 2012
- 124
Hi All,
I've been struggling with a constant fuel restriction alarm at around near to WOT on a 1993 Evinrude 150 intruder (E150GLETG). Starts and idles great (albeit an occasional miss), but also occasionally overheats if idling too low under load. Without a load it never overheats at any RPM. I believe the vacuum alarm to be true, but I haven't tested the vacuum yet. I've done a lot to this motor, including:
1. Changed out OMS pump for two conventional fuel pumps (in series) with a conversion bracket. I now run 100:1 Amsoil outboard premix. Pulse limiter changed out with full flow nipple.
2. Completely rebuilt all 6 carbs, used a sonicator for cleaning with Simple green. Used Systematched parts.
3. Brand new o-rings on fuel distribution rails.
4. Decarbed with Power Tune
5. New QL16V spark plugs
6. New water pump assembly
7. New fuel primer bulb and hose
8. New fuel fill hose and new 3/8" fuel supply hose.
9. New inline K&N filter (glass housing)
10. Anti-syphon valve removed from tank.
Diagnostics I have performed, are running with fill cap off to test vent, and appears to be venting fine as alarm still goes off with fill cap off. Bulb also doesn't appear to collapse. I have noticed a small leak at the VST fuel supply inlet at the filter (new gasket on the way) and I've also ordered VST bowl gasket and primer solenoid seal kit. Could leaks at these locations cause a fuel restriction issue?
Should I eliminate the K&N filter and let the VST filter do all the work? Maybe too much pressure drop with the inline filter? I have blown air through tank diptube and I can hear it bubbling, but I haven't pulled it yet, saving that for very end if I absolutely have to as its hard to reach.
Thanks for the help!
