1993 15HP compression test resulted in 136 psi & 138 psi
909
What is considered the highest compression possible ( new from the factory )
jimmbo
While you're running it, run a can of Engine Tuner through to make sure the Rings are free
jimmbo
That's pretty good for a 15. We used to get 55 out of a 35hp on a 14ft cartopper
  • Like
Reactions: 909
909
jimmbo
Just a bit of info. If you were using a GPS for speed, you have to take into account any Current there is in the water, GPS is measuring Ground Speed, not Water Speed.
909
The additional wave speed is cheating a bit.
Sort of like when women wear push up bras.
Their titties aren't that big, or perky.
flyingscott
An answer from someone who can read
I typically get 120-ish as well
If possible, I'll run it WOT on water then test it on land
Spraying oil in the cylinders and testing compression right away is a false test. If you spray the cylinders with oil wait overnite then do the compression test.
