1993 40hp knock
hardly
Had someone look at my motor today, told me it had a knock. I thought they all sound this way like a rattle when you rev up and down. So he moved the fly wheel by hand and you do hear a knock or click before it catches. Is this normal?
bktheking
Re: 1993 40hp knock
Not usually, a knock is not normal in any motor. There are different ways to check for play without tearing it apart, search the forums for diagnosis info.
hardly
Re: 1993 40hp knock
So has someone turned their flyweel back & forth and heard this click or knock or do I have a big problem. The motor runs great but he said he would have to go into it may cost up to $2500 to rebuild
bktheking
Re: 1993 40hp knock
Usually a knock is heard while the motor is running, you may just be hearing the motor internals moving inside while turning the flywheel. A knock is evident, if you've owned this thing for a while and it sounds the same as always chances are its fine. If you are worried about it take it to another mechanic and get a second opinion.
