FuelishBehavior
Thread starter- Joined
- Aug 7, 2012
- 139
Over the weekend, the actuator lever on my fuel pump was worn down to the point of no fuel pressure so the engine starved for fuel. The culprit, no gear lube in the fuel pump provision at the sea water pump. I have removed the pumps, the fuel pump will have to be replaced. However, the sea water pump still rotates but it doesn't seem to be perfectly smooth and the slip ring that rides on the lobe/shaft shows significant wear. Since a new sea water pump is $600+, I'm thinking of just rebuilding it by changing bearings and seals along with new slip ring and pray that the shaft/lobe is fine. My questions are this, has anyone ever rebuilt one of these units and do you have any tips/info on this?
Secondly, fuel pumps are upwards of $150 to $200. However, Airtex Part No. 60932 seems to be a direct "marine" replacement for these pumps and are about $50. Has anyone had any experience with these fuel pumps?
