1993 70hp Quick Connect Fuel Fitting
Fish_This
Hi All,
I was wondering if someone could possibly help me. I need to replace the Quick Connector going from the primer bulb to the engine. Does anyone know the size I will need? I have the SeLoc Manual but it mentions nothing about size from line to engine.
Thanks
jtexas
Re: 1993 70hp Quick Connect Fuel Fitting
Johnson/Evinrude, OMC, BRP, style of fittings, are all the same and there's only one size. Not all hoses are the same diameter, but only you can see what size hose you have.
Daviet
Yep, just match the hose size to the quick disconnect fitting and you are good to go.
tashasdaddy
get johnson/evinrude conector, there are many look alikes, that do not fit properly. other brands have started using these type connectors.
