ct1762@gmail.com
Ensign
- Joined
- Jan 17, 2019
- 941
hi guys. friends motor i'm working on.This motor is a tricky one! It wasnt sparking on all 3 cyl... #2 only very weakly. I tested stator (250v charge coil cranking, ohm test good), timer base (again, voltage and ohm good as per manual with DVA). took off the flywheel and it was rusty.. both stator and timer base so replaced them brand new . Pack cranks out 190v with the load adapter, and again 190v when connected to coil terminal extenders cranking DVA. I replaced 2 coils that were suspect... bam hot spark on all 3 cyl now. BUT... top cyl not firing. Has great 1/2'' spark, took carb off and cleaned it thoroughly (done 100 of these). still not firing. Squirted fuel mix into top carb... no change. compression 130-135psi on all 3. Primer bulb stays hard and no change when squeezing. replaced the flywheel (lapped on to taper of course) from a known good sparking motor since this was was so rusted, especially the timer base ring magnet.
Now heres the odd part: #1 cyl, when all other plug wires are disconnected, fires! its trying to run on 1 cyl so dies out of course, but confirms its got spark and fuel... but when you reconnect all 3 plug leads and pull #1, no change in RPM at all like the others. plug on #1 looks wet like all the rest. I will do a running voltage test next to see if its the pack, but how could this be? i tried another pack and same result. is it possible its running on all 3 cyl? how is that possible when the drop test shows no RPM drop when only the #1 plug wire disconnected? it sounds like 2 cyl as well... very lumpy idle and slow to rev up.
