1993 70hp Tilt-Trim Issue
Fish_This
Hi All,
I am having an issue with the TNT, when the engine is running under load I cannot use the trim button on the throttle to trim up and down. I need to do into neutral then it works fine. ASny ideas where to start looking for the issue?
115johnson78
Re: 1993 70hp Tilt-Trim Issue
Make sure all the wire connections are good.
Check fluid
Check to see if motor is strong enough to power when the motor is under a load.
Is the trim switch in the side of the control handle? If so I would either try going slow or put boat on the trailer (and of couarse engine off) put in gear and see what it does. It may have a pinched wire??
