okditch
- Joined
- Sep 6, 2009
- 23
motor will start and run with enough voltage...12.2+v,but seems not to be charging (fish finder voltmeter shows only batt. voltage when it used to show 13.5+-v).LOAD TESTED BATTERY OK. I took off neg batt. lead to motor tested (with key off) amps on black multi lead to the cable and red to battery terminal(NEG) meter read a BACKWARDS draw of 40mA (i think ).DOES THIS MEAN MAYBE THE RECTIFIER IS DRAWING BACKWARDS???ALSO THIS IS AN ALL ALUMINUM BOAT IF THAT MATTERS.I ALSO GET A REVERSE DRAW FROM THE CABLE(BLACK)TO THE HULL(WITH NO NEG BATT CONNECTION) CAN ANY ONE DECIPHER THESE RESULTS?BOAT WAS TRAILERED DURING TEST, AND BATTERY WILL DRAIN AFTER SEVERAL DAYS.I BOUGHT THE RECTIFIER/REG, SHOULD I ASSUME THATS THE PROBLEM AND SWAP IT OUT? THANKS FOR YOUR CONSIDERATION!
