lgrouper03
Thread starter- Joined
- Nov 28, 2007
- 21
Like so many other posts I've read, what started for me as a "soft spot" fix in the floor, has turned into rotted stingers and transom. I am in the teardown stage now. After reading several posts and looking at what I've got, I think I will attempt to cut out the transom from the inside. I've read that I should leave a 3" flange around the perimeter of the transom to maintain the strength at the corners. My question is, how do I insert the new transom piece if the hole that I've cut is smaller (because of the 3" flange around the perimeter) than what I'll be inserting? Also, am I crazy to think about doing this without removing the cap? Thank you.
