1993 commercial 100 v4 - No power to Motor
soburke
Hi there,
a new boating season and a new problem, go figure! I have a 1993 commercial 100 v4, pulled her out of the garage this weekend, went through the cold start procedures. I used the trim to raise and lower the motor, she tried to start (starting motor engaged, flywheel turned, etc.) for a few and then died.
Tried again and the motor is dead. By that I mean the trim is not working it is not turning over, nothing. It is as if I shot a main fuse to the motor. I've done the following:
1. I have verified I have 12.5 volts at the battery, and to the motor. (tested at the motor connections)
2. Checked every fuse in the forward panel.
3. Tried to trim with the buttons on the motor and the remote, noting.
I am not sure what else to check. Feel like I am missing something simple as it appears to just be turned off. Starter solenoid?
Any help is appreciated, thank you.
Stephen
