1993 evinrude 115 ignition problems???
chads30
Tried putting boat in the water today.
Problems...
It ranges from just cranking...all the way to starting and running for 10 seconds. New plugs, etc.
I thought I flooded it because it started the first try of the day and then cut out after 20 seconds and wouldn't start anymore.
Then would only start periodically for 10 sec of so every 20 tries.
I didn't want to burn up the starter or anything.
Mechanic said he will check out ignition parts such as stator, etc.
What could be wrong? Any experience?
tashasdaddy
Re: 1993 evinrude 115 ignition problems???
you start with, trouble shooting steps. compression, spark, and fuel. it could be any of the 3 or a combo.
chads30
compression is 130+ in all 4
spark is okay
fuel is brand new as is oil
