1993 evinrude 175
OOGA BOOGA
the problem im having is i can take it out one day ride for a while then the next day i try to go out and the thing will not start no fire to the plugs at all. then if i unplug the power pack from that lil sensor on top and plug it back in it will fire right up can anyone help me with this ... I also just bought a water pump for it and need info as to how to get to the pin that is holding the shift lever on ......
the454assassian
Re: 1993 evinrude 175
check the top secret file thats pinned up top. I have to replace my water pump impeller also and just finished reading it about 10 minutes ago. very good write up on many items.
OutOfControl
OOGA, here is the Gearcase Servicing procedure for my '98 J150, this should also apply to your model. I'll let the heavy hitters help with the electronics.
boobie
That " lil sensor on top" may be giving you probs.
