tlt9mm1965
- Joined
- Jul 8, 2012
- 2
Problem?
Boat idles and runs smooth at low speed, when you start to throttle up the rpms just die down as if it's not getting fuel.
When you push the primer it takes off then dies back when ever it uses the fuel.
So far.
I have torn down and cleaned both carbs reinstalled, same issue.
Checked to insure both carbs are still in sync
I have rebuilt the fuel pump, had a small hole in one of the rubber valves, thought for sure that had it, but no, same issue.
I have cleaned the tank and replaced all the fuel lines from the tank to the carbs and still no luck.
Can someone give me some direction on what it may be.
Thanks for any advice you may have
So far.
