1993 Evinrude Intruder system check gauge ?
KirkSpock
Hello
I have a 1993 evinrude intruder 175 hp model e175glet
is there a system check gauge i can install in the dash ?
part # ?
Thanks
miker
Chris1956
Honorary Supreme Mariner
Re: 1993 Evinrude Intruder system check gauge ?
See if you have the 8 pin DIP plug, under your dash. If so, look for a system check tach. One brand is Faria. The other may be teleflex.
BTW - I think you will only have a 3 wire VRO Pump. That will limit your alarms to overheat, fuel restriction and low oil. A 4 wire OMS pump would give you the additional alarm for no oil.
KirkSpock
Hi Chris1956
Thanks for info
VRO was removed before i had boat, would i still get the overheat , Fuel Restiction ?
thanks
miker
daselbee
Can't do it. They went to the deutsch connectors and systems check in 1996. Your harness will not match up, and you will not have the separate and distinct sensor leads that plug into the systems check gauge. Those would be the tan/yellow, tan/black, tan/blue, etc leads that run up to the tach in the boat harness. Besides, it is a lame "feature" anyway.
