Re: 1993 evinrude ocean pro wont start
No.
The problem is caused by power not traveling through the ignition switch to the small post on the starter solenoid.
Power travels to the ignition switch on the Red/purple wire connected to the "B" post on the ignition, and back to the solenoid on the red/yellow wire connected to the "S" post on the ignition.
If the ground wire from the other small post on the starter solenoid is good, and if the circuit through the ignition switch is good, turning the key to start will activate the solenoid and run the starter motor, provided the control arm is in neutral and the neutral safety switch is good.
