1993 evinrude throttle lever removal
fredcombs
Hello all. I need to replace my shift cable and am in the process of removing the throttle lever to get to everything. I have the lever off but I see no way to get the guts out of the inside. There is just not a hole big enough. Any tips would be greatly appreciated
Honorary Supreme Mariner
What control box.--Pictures of it ?-----The common control box splits down the middle to work on all the pieces inside.
fredcombs
No Title
Here is where's I am currently
fredcombs
I am almost to the point of cutting out an access panel so I can get it out lol
jakedaawg
Well, you bought into a heap of it...
1st, remove the trim tilt switch from the handle if you cannot reach behind to unplug it.
Then you will need to slide the control box down the gunnel usually toward the stern until you can gain access to it.
You will also need to reach in there and disconnect the two yellow with red strip wires. There should be bullet connectors on them if it was rigged properly.
You may need to unhook the cable ends from the motor and feed those back as well as you slide the box down the gunnel.
Good luck!!! Thats a pain in the rear job. The new kid at the shop gets to do those...
