FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
It is a 1993 evinrude 30hp model # E30EETA when I turn is key all it does is chrip then nothing. I jump it and it started, so that would mean that my solinoid is bad. anna
If I understand the problem, it could be the ignition (start) switch, the neutral switch, the starter solenoid, or a bad connection.<br /><br />c/6<br /><br />Hooty
akillian,The high pitch chirp noise is likely a weak tone from your control box giving the initial alarm circuit confirmation signal when the key is turned on.Insure that your engine grounds are clean and tight.
OB, I have a good battery a good ground. when I check out volt. from the key switch to the solinoid is good, but from the solinoid to the started is dead. Could this mean is it bad. (solinoid) <br /><br />------------<br /><br />thank you anna K. <br /><br />ps thank you for helping me.
You can test solenoid by jumping from the large continuous 12 v cable on inlet side of solenoid to the small ignition terminal of solenoid and see if the starter engages.Be carefull around flywheel when performing this test.
