1993 Force 90 Stator Question
alounsbury
I have the Seloc manual for this motor and it indicates that the stator resistance for the low speed stator should be between 5500 and 6200 ohms. I am currently measuring 3200 with my Fluke. I am reasonably convinced I have a LS stator problem since I have erratic idling (great when cold, unpredicatable when warm) and stalling on slow accerleration only when warm.<br /><br />I recently saw on another web site that the LS Stator resistance should be bewteen 3250 and 3650 - which is close to what I have and hence the reason I am asking. So - can someone please tell me the correct answer for the LS stator winding resistance. The stator is an orginal black (I know from other posts that this is apparently the problematic one)for information.<br /><br />Thanks
lonewolf5347
Re: 1993 Force 90 Stator Question
THE STATOR IN THE BLACK HOUSING ARE MERC. @ FORCE ARE THE PROBLEM ONES. TRY READING A RESISTANCE ON OHM METER X 1000 SHOULD BE MORE THAN 600 OHMS ON LOW SIDE AND HIGH SIDE .IF YOU NEED A STATOR TRY www.seilermarne.com
