1993 Johnson 115 measuring head temps with IR gun?
rothfm
Ensign
Hi,
I believe I'm ok with appx 135-145 shooting around the head covers and heads. Some places down low are 115-125. But mostly I see 135-145.
But, If I aim deeper toward the inner/back of the piston area...I can see temps in a couple spots at 150-161. Is this normal, if the areas around and on the heads are aok? Where should I be measuring to ensure I'm ok?
Sensors/alarms are aok and I just did bubble back tstats, head gaskets etc..The head have good flow out the hoses. Maybe I'm just bieng a worry wart!!
Thanks
Bosunsmate
Re: 1993 Johnson 115 measuring head temps with IR gun?
160 would be fine with me, is that at idle?
rothfm
Ensign
hi, Ya-on muffs. The prior owner had t-stats out for some reason. I did some work and initially liked the readings till I saw a couple spots in(forward) of the heads at 155-161 degrees...Both sides, other than that most of the locations I shoot are 120-145 depending on location. I think I'm good I HOPE!
rothfm
Ensign
Oh, and I did the deflectors as well, were flat. Just curious of the higher temps in a few spots.
toddschubert
Mine reads same way. For monitoring purposes I put a temp gauge in w sensor on top of t stat housing centered. It works great gives same temp as I'd gun. You won't know what side is hot but the alarm doesn't tell you either
rothfm
Ensign
Thanks Todd, Remember you did that when we talked about my 88spl. Thanks. Good to know it seems normal.
Might be a water test today.
I really want to do that at some point, I have room for 2 small guages and will monitor each bank.
toddschubert
dual guages would be the best thing to have good luck
rothfm
Ensign
UPDATE: Continued monitoring and starboard side, runs hottoer even on the head (149-154) than the Port. Good flow out hoses and thru exhaust leg. I still suspect one of the Tstats bought on Ebay. Going to get OEM stats this week and swap again.
bubble back, but I've done it twice now successfully, with extra hands!! I'll update if this drops the bank down to 143+- as i expect.
mrmamiller
I have a 1986 110HP Johnson. My starboard side runs hotter by about 5 degrees. I don't worry about it, as I went through a lot to get it to where it is now. I have temp sensors epoxied near the overtemp switches so I can watch the temps as I run the boat on water (not so easy with the IR gun). My hottest temps are at idle, which is what I was looking for, as they were way to cold before doing a thermostat job. I can now run for hours at low speed in gear without a hickup. Yeah, bubble-back is a real treat!
rothfm
Ensign
Hey, thanks for that...make me feel better. I'll get buy the new stats but maybe wait to do an in-water test vs just the muffs. not an easy chore to do em. See what happens first.
thanks again.
