FED, I replaced all the gas hose from tank to motor, anti siphon removed, squeeze bulb and filter so all fuel delivery is new except fuel pump. I understand what you are saying and I don't know if the motor has a fuel pressure vacuum switch or not. I will try to find out. Any idea where it might be if it exists? When running WOT the motor runs runs very smooth, can't notice any bogging down or hesitation. Just a constant alarm. The heads were almost plugged with sand and salt which is likely causing it to overheat.
