bassFISHIN
Thread starter- Joined
- May 26, 2008
- 25
Had the boat out today for a full day of fishing and apparently left one start too late. Dead on the Water. All day I had been having trouble idling with the engine cutting off but when it got past a certain point it ran great. After the last cast we decided to head in, then I couldnt get the engine to turn over. It would crank but it just wouldn't finish the job. I had 12volts on the battery and thought after a few cranks may have flooded it so waited another 15 minute to give it a try and nothing. Eventually I burned the battery out and had to be towed in by a jetski. After we got in I noticed gas coming from this little hole in the lower unit. I have seen this hole before but never really knew what it is or its purpose. I couldnt find it in the manual. But anyways this was the first time I seen gas coming from it(as seen in the picture I attached). I had the cranking battery tested for kicks after I came in and Autozone said that the battery was no good-even though there was no charge on it(bought new last summer-duralast). Not sure if this would make a difference or not. Any help or input would be greatly appreciated. Thank you.
