jaythebaron
Thread starter- Joined
- Aug 12, 2010
- 15
Hi,
I am having an issue with my shifter. When I crank the motor in the neutral position the prop spins rather fast as if it's in forward gear. There is a very small area that I can sometimes find neutral. When I try to get it in reverse it's a struggle and almost sounds like it's ripping into reverse. Needless to say, I quit doing this fearing that I may tear something up worse. Is this a simple adjustment to the throttle or shifter cable or is it a linkage problem? The last time the lower unit was off was about 4 years ago to replace the water pump impeller. Also, does anyone have any tips on how to fix this? Thanks in advance!
