roscottjr
Thread starter- Joined
- Jun 10, 2006
- 330
Rebuilt my lower unit due to a gear going bad. Lost about 4 teeth on forward gear and also on the pinion gear. Reverse gear was fine. I found that the forward gear bearing didnt look so great on one side. My new part consist of: forward gear, reverse gear, pinion gear, clutch dog, both clutch dog springs, forward and revers gear bearings and thrust washers, water pump set, lower unit seal set. The remaining bearing in the case looked and checked out fine as per manufacturer specs. I reassembled the gearcase useing the recommended oils and greases where noted in the manual. Filled unit with recommended hi-vis gearcase oil. Started engine (on muffs) and ran for about 15 minutes changeing between forward, neutral, and reverse gears to make sure everything was operating correctly. I also used a mechanics stethoscope to listen for sounds in the gearcase but heard none. After running I shut it down and removed the lower drain screw and upper screw to be sure it was full of fluid and noticed metal particles on the magnetic screw. Nothing big but more like tiny particles or tiny shaveings. I cleaned all the metal off the screw and my plan was to do this several more times and see if it is still doing this and if so then take the unit back apart and se whats going on. Does anyone have any suggestions or is this normal and I am just jumping the gun here.
Robert
Robert
