1993 Johnson V8 250hp Outboard
skidog519
I have a 1993 Johnson V8 250hp Outboard motor and although it is still in the water, last weekend I lost my reverse completely. It just clicks when I put it in reverse and goes no where so I am assuming something has happened to the linkage, or gear box but no problems at all with forward.
I am gussing I cant do anytyhing until I pull it out of the water for the winter so I can pull the lower unit off but if anyone has any thoughts or ideas on what to check it would be appreciated.
Thanks
tashasdaddy
Re: 1993 Johnson V8 250hp Outboard
could be bad shift cable. disconnect the cable at the motor, and shift the motor manually at the motor. if it works then you have a cable/control problem.
