j_k_bisson
Thread starter- Joined
- Oct 6, 2010
- 1,082
I recently purchased a 1993 Pro V with a 1993 75hp Mariner 3 cylinder on it. I have worked thru all the other issues with a motor this old; carb rebuilds, link and sync, faulty coils, new water impeller, new fuel lines, removal of oil injections system, etc....
My current problem is a rough idle. I have traced it back to the block not heating up and an excessive amount of water coming out of the tell tail. Also i mounted a water temp Gage on the motor. The temp Gage is not registering any temp at all. I have tested it with a heat gun and it works, I have also replaced the sender 2 times thinking it was a bad sender.
I have also puller the t-stat and diaphragm . The Diaphragm was not sticking, and the T-stat dis work. I replaced it with a new one and went with a 145 degree. Thinking that this will increase the head temp. It did not make a difference.
So My question here is, what else to look at. I check the factory service manual for a water flow diagram and there was not one like the Johnson factory service manuals.
1) Does anyone have the water flow diagram for this motor and can share it with me.
2) What other possibilities could it be that is causing the water pressure to be high? Possible some plate flipped upside down when changing the water pump impeller? Blocked let off hole in the water pump, etc.....
The motor is running not bad at idle, a bit shaky and occasional kick back. I am trying to make this motor run like a new one. Compression is 125-124-125 top to bottom.
Looking for any and all possibilities for this issue.
