Rick Fernandez
Thread starter- Joined
- Apr 16, 2007
- 19
Hello All,
Need some advice and help again please. Three months ago I had a temp rising at idle issue and I was advised by many here on the site to replace the impellar, which I did do myself and the boat's temp was great for awile after that, temp was reading 130-150max at all times. BUT, just recently our last time out on the water the boat was getting hot while driving, temp going over 175-185, wants to hit 200. Also while flushing with muffs, engine on, just doing a test, temp got hot again in only 4 minutes...I have a feeling something got lodged into impellar or the waterpump/thermostat, just not sure which one could be causing the problem?? Also, noticed something during flushes that I'm not sure about: Flushing with the muffs, water is exiting through certain holes of lower unit, and when flushing using the quick flush hose, the water exits only through two larger holes located near opposite sides L/R of the lower transom, but don't see it coming out of the same holes of when using the muffs....is that normal??? I never noticed this before...please advise!
I want to get out on the water tomorrow
All your help is greatly appreciated! Rick
